No service
09-10-2019 07:15 PM - edited 01-05-2022 07:00 AM
I recently transfer to public mobile. I retain my old #. Until now I could not receive or make a call or txt.I already PM moderator but no response. What to do next?
Joining Public
09-11-2019 09:06 PM
@BrianplaineagleTry swapping your SIM card with another phone to make sure it is the problem with the service not with your phone.
09-11-2019 08:53 PM
Hi I added money to my account an it never Restored my plan
09-11-2019 08:48 PM - edited 09-11-2019 08:49 PM
@JhunH wrote:It been 72 hour no moderator response. I was not able to create self serve account because I can not receive or send text and I can not also make or receive call. I was able to contact telus porting center they said port is complete and everything is active and the problem is the sim card. Is there a way to create a self serve account with receiving a verification code thru text so I can change my sim
You can't without working text service. The code is needed. The only way without code is for moderator to do it.
09-11-2019 08:45 PM
09-10-2019 08:02 PM
1. Does "Public Mobile" appear on your phone ?
2. If yes, Call 611 and let us know if it says something about your account. Does it say it is suspended?
3. Are you able to login to self serve? Take a screenshot of your overview and post it here. We may be able to give you an idea whats wrong.
09-10-2019 07:18 PM
What model phone do you have?
When did you port your number and from which provider?
Have you tried rebooting your phone?
Does anything work on your phone? Text in/out, call in / out, data?
Did you get any texts from Public Mobile that port was complete?
More details you can provide the more info the community has to assist you.
09-10-2019 07:16 PM - edited 09-10-2019 07:17 PM
@JhunHIt takes a moderator 48hours + to get back to you. So you just have to be patient. In the mean time put your old card into your phone to see if that is working.
