No service in Vaughan
crazycolby
My phone is stop service and still searching .......
7 REPLIES 7
Acekiller
sometimes it is just a matter of restarting the phone.
matbasm
Any chance you can try your SIM in another phone, to see if it works?  Or perhaps try someone else's SIM in your phone to rule out a problem with your phone.
Michael77
@crazycolby wrote:
I have tried turn off the phone and turn on the airplane mode, I think it is time to change a new phone......
@crazycolby,
Has your issue been resolved?
crazycolby
crazycolby
it works before, I am going to change my phone,
MK78
Could your phone be locked to another carrier?
Does it work elsewhere on PM?
zhadj030
Have you tried doing the basics ? Turn on airplane mode on for 1 min and then off. A simple restart. What phone are you running ? Clean the sim card tray for dust. And finally try manually setting the network to public mobile
