No phone service??
immyonlyfan
Hey I am not receiving calls or texts. Does anyone else have this problem right now??
9 REPLIES 9
homelifegolcond
check if you pay
rliu1993
try restart phone and check the setting
shep22
@immyonlyfan hi do you have do not disturb enabled accidently?
@immyonlyfan So, your account is showing ACTIVE on Self Serve?
If so, then try the other tricks the others are saying in this post.
Hope this gets you up and running again.
gblackma
@immyonlyfan try a network reset and restart your phone if it doesn't automatically do so. Stay safe.
Staliger
@immyonlyfan Check your account. Is it active or suspended? If suspended, do a manual payment. Otherwise, restart your phone or use fly mode for a min.
gpixel
@immyonlyfan
  •  try restarting your device
  • airplane mode enabled/disabled
immyonlyfan
No, I am in the middle of my cycle.
Hi @immyonlyfan ,
Did you have an autopay that failed?
Check your self serve account.
