09-09-2016 11:21 AM - edited 01-04-2022 03:13 PM
It's been kinda annoying lately and I would really like to know how to set up outgoing caller ID so that at least it shows my number.
Service
10-29-2018 06:53 PM
You may want to reboot your phone.
Otherwise, you may have an incomplete port and need to contact moderator. Unfortunately, since they are very busy, it may take a few days to resolve issues.
Here is instructions to contact moderator:
Recommendation: do not send multiple message to moderators. Each new message will put you further down the job list.
Or just send a private message through the following link :
Please include in the private message your account number and PIN code.
10-29-2018 06:51 PM
Hello,
I bought a new Publicmobile plan today of 20$ per month prepaid, which has unlimited province wide talk, I face the same issue as posted, Whenever I make a outgoing call, the other party dont see any number and sees it as Unknown.
I am using factory unlocked Apple iPhone 6.
Please advise how to resolve this issue.
Thanks
09-09-2016 12:43 PM
Hey @GroovyBro
No caller ID indicates that your number is blocked. Have you recently dialed #31# before a number in order to block yours ?
Try adding *31# before the 7 digit phone number, see if it makes a difference.
Let us know if you need further assistance.
Mary
09-09-2016 11:34 AM
09-09-2016 11:32 AM
I would PM one of the Public Mobile mods. It sounds like something was not setup correctly in your system record when the number was created. I know they can be configured to not publish out etc. or remain anoynmous.
09-09-2016 11:31 AM
What type of phone are you using? There might be a setting that was enabled to block your number
