No data
07-15-2020 12:57 PM - edited 01-05-2022 12:27 PM
So i payed my bill 3 days ago data worked fine untill today.. now I get a x where is says lte and I checked my usage and still have 3gb remaining.. is this a service issue with everyone or what's going on? Been a customer for years never had a problem thanks all
Service
07-15-2020 01:33 PM - edited 07-15-2020 01:34 PM
@Bmoff yeah this was happening to me too, I would just switch to HSPA then back to LTE.. idk what it was.. I just recently downgraded to the 1gb plan since Ive been on wifi more often. so I haven't been able to monitor it... one thing you can do is reset your network settings
- open your settings
- scroll down and tap system
- tap reset
- tap network settings reset
- tap reset settings
- tap reset settings again
- restart your phone
07-15-2020 01:30 PM
@Bmoff wrote:Not in a basement but in the the city maybe that's why? It's a Motorola g8 and it's been working fine on the lte bands I checked it all before so unless they changed it it should be compatible.. also it worked for months on lte no problems legit just started today!
It could be a local network issue. If the conditions persist, then it is likely a phone problem.
07-15-2020 01:25 PM
@Bmoff Moto G8 has great LTE band support so that is definitely not an issue in your case.
07-15-2020 01:20 PM
07-15-2020 01:11 PM - edited 07-15-2020 01:12 PM
@Bmoff wrote:Thanks!! Switching to 3g worked for now at least I have some data but whenIwhen switch back to lte it works for a bit then stops again
@Bmoff That means the LTE connection in that are is weak. Are you in a basement or underground? What kind of device are you using? Does it support most of the LTE bands that PM uses?
07-15-2020 01:09 PM
It's newish but it's been working great for months but I'm not in my area atm maybe it can't find a lte signal? 3g is working fine now
07-15-2020 01:07 PM
07-15-2020 01:02 PM
@Bmoff wrote:So i payed my bill 3 days ago data worked fine untill today.. now I get a x where is says lte and I checked my usage and still have 3gb remaining.. is this a service issue with everyone or what's going on? Been a customer for years never had a problem thanks all
Did you check that usage in the self-serve? Or your phone?
Is this a newish-to-you phone? Or have you had it for some time?
07-15-2020 01:00 PM - edited 07-15-2020 01:02 PM
- try restarting your phone
- toggle airplane mode on/off
- checnge your preferred network to 3g for a minute then back to LTE
