03-03-2025 08:56 AM
I just switched to PM from rogers.
I have a S23. I've reset the networks and I've restarted my phone. As soon as I turn off my wifi I have no connection to the internet. My data is turn on in my settings.
What am I missing?
03-03-2025 12:56 PM
I tried for the second time now to reset the network and restart my phone. The problem is solved now! Thanks for your suggestion!
03-03-2025 12:40 PM
My service to rogers is canceled.
I have an esim so I can't test it on another phone
03-03-2025 12:39 PM
Do you have service on the Rogers side? Do you have access to another phone to test the PUBLIC Mobile SIM card?
03-03-2025 12:18 PM
The old sim is removed, I have reset the networks and restarted my phone. It still doesn't work.
03-03-2025 09:29 AM
hi @Julie93
make sure your old sim card is removed, or if it is an esim ,disable it
then reboot the phone and try Reset Network settings and it should work then
