No Service
10-04-2021 05:24 PM - edited 01-06-2022 03:29 AM
Hi,
I have an unlocked iphone 6s that I'm trying to use with Public Mobile. I've received the SIM, activated, and put it in the phone but it still says "No Service". I know it's unlocked because it says so in the bottom of the about section where "Carrier Lock" says "No SIM restrictions". I've also tested my eastlink sim in the phone and it worked fine. I've tested the Public Mobile SIM in my iphone 12 and it worked there no problem. But for some reason when I put it back into the 6s it says "searching" and then "No Service". No other messages.
I've rebooted the phone, reset network settings, reset the whole phone, removed the SIM and waited and then re-inserted it...all with the same result.
Any help would be appreciated.
Service
10-04-2021 07:56 PM
@JaredCoady wrote:Hi,
Important, check to make sure your IOS is fully up to date on your iphone 6s.
If there is an update to do, to it. Then, perform another Network Reset.
10-04-2021 06:31 PM - edited 10-04-2021 06:33 PM
if you try in another device and the SIM card working fine, then issue with your device or locked device, and need to unlocked iPhone, from where you get it !
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
and maybe your device defective,
first try to do erase all content and settings Here link, or Here link,
10-04-2021 05:51 PM
Go to Settings > Cellular > Cellular Data Options. An option like Cellular Data Network indicates an unlocked iPhone.
10-04-2021 05:27 PM - edited 10-04-2021 07:32 PM
Check for a Carrier Settings update (Settings -> General -> About)
Edit:You may need to check for the updates by connecting the iphone 6s via USB to your PC and running iTunes
