No Service
05-22-2019 11:03 AM - edited 01-05-2022 05:02 AM
I've activated my account and my phone number has switched from Koodo. The phone seems to recognize in the settings that it is a Public Mobile phone now, but in the top left corner where it should say Public it just says no service. I went to the site and downloaded the APN info and applied it, I also restarted a few times. I must be missing a step.
Lucas
Joining Public
06-08-2019 03:46 AM
You must set the carrier setting in the setting application on your phone to “automatic”
05-22-2019 12:06 PM
Try your sim in a different phone, sounds like the activation did not go through correctly.
05-22-2019 11:24 AM
Since Koodo and Public are more or less the same network we can rule out incompatabilities.
Where did you get your phone? Is it locked to Koodo?
Do you have another phone you can try the SIM card in?
05-22-2019 11:19 AM
@lucascandy, I am a little puzzled by your explanation. You say the notification shows Public Mobile is the network your phone is on, but yet the phone shows no service. Having service is how the phone is able to determine the network. Does your self serve account show active status? I would ask some questions about SIM lock, but again you say the phone settings show Public Mobile and you get can't get that far with a SIM locked phone.
05-22-2019 11:09 AM - edited 05-22-2019 11:11 AM
@lucascandy wrote:I've activated my account and my phone number has switched from Koodo. The phone seems to recognize in the settings that it is a Public Mobile phone now, but in the top left corner where it should say Public it just says no service. I went to the site and downloaded the APN info and applied it, I also restarted a few times. I must be missing a step.
Lucas
@lucascandy What type of phone is it? If it's Android go into settings -> Network & Internet and make sure the Mobile network is set to auto and not Koodo.
