No Incoming / Outgoing Calls
Shananahan79
Neither my husband or I can place or receive calls, but everything else works. Anyone else?
20 REPLIES 20
Kith
I'm in Ontario. I can't make outgoing calls. I've tried a couple of numbers. When I try to connect a call, there is silence for a long moment, and then "call failed."
jean1963
ok just tested can get incoming but cannot make outgoing
jean1963
same
MarkSquires
Called both the Alberta and Ontario numbers and same issue. Phone says "calling" with no dial tone and nothing happens
michyNB
rebooted, issue persists
MarkSquires
I appreciate the feedback but as this issue seems to be in other provinces and more of a broader network issue, I'm not going to wipe my network settings. I've called multiple numbers, and I've completed numerous reboots/restarts
michyNB
we get that on the first call, but if you try the same number again after that call drops/ends we get the 22P1 error. funnily we can call each other though, and we're both on public mobile, and we were able to call a friend on public mobile in Ontario too... but we hit this issue trying to call the MILs rogers home phone line.
@MarkSquires wrote:
Tried multiple numbers and same issue
@MarkSquires
can you try calling these 2 PM voicemail numbers in another pronvice?
587-580-4001 Alberta
778-580-4002 BC
@overdriver
if you have a physical sim and you have another phone around, please try the sim card on another phone.
Also, do you have another phone you can test calling yourself to see if you can receive calls?
MarkSquires
overdriver
I already tried rebooting my phone and tried calling an actual phone number.
Resetting the network settings on an iPhone clears all WiFi networks, VPNs, etc, so that's not something I'm willing to do at the moment.
MarkSquires
Similar issues with me in Newfoundland. I can receive and send text messages but can't receive or make calls.
@overdriver / @Shananahan79 / @michyNB / @MarkSquires
please try Reset network settings after a device reboot.  Please try calling different numbers (please note there is a problem with voicemail in Ontario)
if issue persists, open a ticket with PM Customer support.
Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account.  Select Start a Chat to begin:
          https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
** If you cannot receive 2FA code via SMS and unable to open ticket, please setup a new Community account using anoth
MarkSquires
Hi - I'm in Newfoundland and I'm having similar issues
Shananahan79
Good to know, thanks!
Shananahan79
We’re not getting errors. Just doesn’t ring and then call drops.
overdriver
I am also unable to make any calls. I'm in Ontario.
michyNB
My wife and I are having similar issues and getting error 22P1 on outbound calls, we're in New Brunswick
Shananahan79
Ontario
@Shananahan79
And are you in BC or QC?
both provinces have " Failure of wireless services for multiple locations" (Vancouver, Whistler, Kamloops, Surrey, Chateauguay, Kahnawake, Lery, Mercier, Saint-Constant, Saint-Remi)
Cause: Undetermined at this time / cable damage
Confirm if it is a network outage issue in your area:
https://www.telus.com/en/bc/outages
