12-03-2018 02:16 PM - edited 01-05-2022 02:41 AM
I have just switched from Kodoo to Public Mobile. The APN is set as https://apn-canada.gishan.net/en/apn/public-mobile/sony-xperia-xz-premium, but still I can not get online. I am using a Sony XZP, bought from Hong Kong. I was able to get online while I was with Kodoo tho, so I have no ideas how to fix the problem. Please help~
Joining Public
12-03-2018 03:31 PM
I did nothing, but out of a sudden, it just works by itself, a miracle! Haha
Thanks u guys~
12-03-2018 03:22 PM
@SharW77 I am still waiting for a miracle to happen.
12-03-2018 03:04 PM
Hey I'm having the same issue how did you get it to work?
Thanks!
12-03-2018 02:43 PM
Hey, and the data is on and I can make phone call and text already. Thanks!
12-03-2018 02:34 PM
1
2
3
Pic attached, thanks
12-03-2018 02:31 PM
Tried, but still no good. T.T
Thanks for your reply!
12-03-2018 02:30 PM
12-03-2018 02:28 PM
Deactivate STAMINA mode and restart your device. To save battery power, STAMINA mode disables mobile data when the screen is turned off.
- Find and tap Settings > Battery > STAMINA mode.
- Tap the slider to disable STAMINA mode.
12-03-2018 02:19 PM - edited 12-03-2018 02:24 PM
@mylololi wrote:I have just switched from Kodoo to Public Mobile. The APN is set as https://apn-canada.gishan.net/en/apn/public-mobile/sony-xperia-xz-premium, but still I can not get online. I am using a Sony XZP, bought from Hong Kong. I was able to get online while I was with Kodoo tho, so I have no ideas how to fix the problem. Please help~
Are you able to post a screen shot of your APN settings? There maybe something in there that was overlooked and someone else might pick up on.
