No Data
cristy01
I do not have data, Even I can not to get and data ad on I already paid. What I have to do.?
I can not to get acces to my account, My e mail is not reconized.
7 REPLIES 7
CS_Agent
Customer Support Agent
Hi @cristy01,
We've responded to your private message. Please check your inbox.
Best,
Syed
Are you on a Legacy or Pioneer plan?  If yes, please dial 611 for assistance.
cristy01
It is not activation, my phones was working well before, PM took maney and No service
cristy01
My phones has been working since many years ago. This info does not helps
cristy01
1st. I can not to create a account.
2. It said my phone is alreded registered
3. It does reconized my emaL
I can not do anything thru this
will13am
@cristy01, how about giving this knowledge base a quick review.  It covers a few things that need to be done after initial activation to get the data working.  This assumes that the plan has been properly set up and has data.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Activate/ta-p/251824
mimmo
Hi, are you a new customer?
Did you set up your Apn setting?  What phone are  you using? There is good info in this thread https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Activate/ta-p/251824
Did you sign up in a store or by your self if in store you need to create an account. https://selfserve.publicmobile.ca/
