03-01-2018 11:46 AM - edited 01-05-2022 04:18 AM
I just got an unlocked Samsung Galaxey A5 a few days ago and all was workign well after impoting my SIM card untill about a half hour ago a friend tried to send me a picture and myu data qyuit working all toghter. How can i fix it?
03-03-2018 03:44 PM
@Korthwrote:Login to your PM Self-Serve account and confirm you have unused data available on this billing cycle.
Again. You may have simply used up all your data.
03-03-2018 12:59 PM
@joetracey1294, As I mentioned a couple of days ago, if it was working on the new phone for a few days, and then suddenly stopped for no reason, send a private message to the moderators team. Let them take a look from their end.
Click here to send them a private message.
You can find information regarding the moderators team by following this link.
03-03-2018 12:55 PM
The problem is it was working for a few days to a week and then just quit, if it was working I don't think it's an issue with compatability
03-02-2018 02:44 PM
change APN Settings.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
and change the network to 3g or else VoLet
03-02-2018 02:30 PM
There are at least 14 different Samsung A5 variants/submodels, at least 6 of which have only limited or partial compatibility with PM (Telus) networks.
You should identify your Samsung A5 model and confirm if it's fully compatible with PM.
Confirm APN settings.
https://apn-canada.gishan.net/settings/883_15_public_mobile_apn_settings_for_samsung_galaxy_a5.php
Confirm SMS/MMS attachments and cellular data are enabled in settings. You don't strictly need Data on your plan for msg attachments, but might as well check everything all at once.
Restart the device. Not strictly necessary, but I'm old school and I like proven solutions.
Login to your PM Self-Serve account and confirm you have unused data available on this billing cycle. If all your allocated data is used up (or was all used up on previous billing cycles) then there might a technical issue the @CS_Agent can correct on their side.
Test whether SMS/MMS attachments work by having a friend send you a msg.
If it still doesn't work properly then contact the mods.
03-02-2018 11:21 AM
Try sending a MMS to your own number!
03-02-2018 11:16 AM
try the network reset option it cant hurt. or possibly a different texting app?
i know i have occasionnaly had this happen to me and it resolved it self within 24-48 hours.
i'm grasping at straws now so i will let others chime in.
03-02-2018 11:09 AM
Unforintly i can't do that last step as my new cell is a micro SIM and my old one wasnt. i tired step 2 and it still isnt working
03-02-2018 11:05 AM
hey @joetracey1294 my first step would be to check your account to ensure you see the data addon (if it is not listed that means you have used up all your data, this however should not impact your mms, so really you could skip this.
also this might help in you apn settings
Set APN type to “default,mms,supl” |
If that fails
I would then put your sim in your old phone and see if you can still not receive mms. this would isolate a phone vs network issue. if network contact the mods if phone I would delete the current apn and do a network setting reset and renter them
03-02-2018 10:53 AM
i have cheakced it 10 times over and its all the same
03-01-2018 12:39 PM
However, @joetracey1294 reported that the phone was working fine for a while. If it was an APN setting issue, it wouldn't have worked from the moment he put the PM SIM into it a few days ago.
03-01-2018 12:27 PM
very true, the APN may need to be reset to default or set to new as PM.
its easy to find the APN setting for PM with a quick search
03-01-2018 12:21 PM
I suspect it is an APN setting issue with the A5. Take a look at this knowledge base link and make sure the APN settings are correct.
03-01-2018 12:06 PM
I have had the acount for a few months now. I just got the cell phone.
03-01-2018 11:48 AM
@joetracey1294, Is this a new account, or have you just gone through a renewal/payment?
If not, you should send a private message to the moderators team to see what happened. This is assuming nothing has changed on your end.
Click here to send them a private message. Include account number and PIN to speed up the process a bit.
