03-26-2020 12:35 AM - edited 01-05-2022 10:05 AM
Hi,
I just transferred my number over to Public Mobile from Virgin and tried to follow the steps (https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone) to set up data on my Samsung Galaxy A5 phone. But under my APN settings there isn't a "MMSC proxy" line, so I don't know where I should enter "74.49.0.18" I tried putting that number under "MMS proxy" and leaving "MMS proxy" blank, but in both cases I can't send a text message with a photo in it. How do I fix this? I took screen shots of my APN page to hopefully help someone give me an answer. Thank you very much!
03-26-2020 12:59 AM
03-26-2020 12:58 AM
Thank you so much for your fast response. You fixed my problem!
03-26-2020 12:53 AM
Make sure data is turned on and you have the correct APN settings.
Instead MMSC Proxy use MMS Proxy and leave APN Type blank (remove default)
03-26-2020 12:41 AM
For MMS proxy .. put this.
mmscproxy.mobility.ca.
On picture below. start with APN type and enter it and make sure others underneath APN type match yours.
03-26-2020 12:41 AM
@Allison3 wrote:Hi,
Put those numbers back in MMS proxy and add ,mms to APN Type.
