New sim card when changing plan?
chocca47
I am currently trying Public Mobile with a $10 plan and received a Public Mobile number. I want to change to a 30-day plan and port in my phone number from another carrier. Do I need to buy another sim card to do this? Apologies if this is a silly question -I'm not very knowledgeable about cellphones.
Thanks for any help.
7 REPLIES 7
Carld123
@Obummichael wrote:
What do I do when my sim is lost and I want to retain my number with public mobile?
@Obummichael
Buy a new sim..go into your self serve and change the old  sim card number to your new one
mimmo
@Obummichael buy a new sim card. Log into self-serve click plans the click change sim.
Obummichael
@chocca47, just make sure to use the account number and the name that is on the account when you port that is all that is needed
* I am happy to help, but I am not a Customer Support Agent please do not include any personal info in a message to me. Click HERE to create a trouble ticket through SIMon the Chatbot *
chocca47
Thank you for your response. I am with VirginMobile so hopefully won't have any problems porting.
Alex888
No, 1 SIM card for any plan, including US roaming addons.
ShawnC13
No you will just need to do a plan change in the self serve and at that time you can also do a change number and port in your current number.  If you are with Koodo prepaid you will need moderator assistance to port in that numbera s they use the same back end computer system
