08-17-2016 05:26 PM - edited 01-04-2022 03:03 PM
08-18-2016 01:08 PM
@Greygoust if you are a current PM customer on one of the older plans and want to move one of the new plans, send @Shazia_K or @Mary_M a private message and they may be able to move you over right away, if you are less than 45 days into your current 90 day plan. Otherwise, you can just go into the self-serve portal and select your new plan. I recommend that you use the option to change plans on your next renewal date and not right away. Let us know if you have any other questions.
08-17-2016 07:23 PM
nice new profile photo @Luddite
08-17-2016 05:53 PM
If you are already a customer do it from your self serve account under Change Plan.
08-17-2016 05:37 PM - edited 08-17-2016 05:38 PM
You will be able to set up whatever is available here: http://publicmobile.ca/en/on/plans
When you pick your choices, the total amount without tax is shown on the bottom.
