New number
Vinnie78
How do I get an actual Owen Sound number?
@Vinnie78For Owen Sound and Telus owned exchanges
For Area code 519- 387 or 377 or 447 exchanges. (looks like they are all out of that)
For Area code 226- 568
You can select the number via this screen
New NumberNew Number
OwenSound new numberOwenSound new number
@GR wrote:
@Vinnie78  there's no guarantee you can get an Owen sound number!   Do you already have an account and wanting to switch your number?  If so go to change number in your self serve and put Ontario and look in the drop down list to see if it's listed, if not you'll have to pick a number from nearby
Owen Sound numbers are definitely available. At the moment Public Mobile is giving out 226-568 numbers.
geopublic
@Vinnie78  Best to do this early morning since Public release new numbers to the pool.
 From your selfserve account (first page) click as shown below and select Owen Sound. Good luck!
iliketotalk
@Vinnie78  hi go into your self serve under change number and pick one out there Smiley Happy good luck
GR
Triguy
Go into your account and pick change number  directly under my profile.
