3 hours ago
Hi, I have not been able to receiving calls or text messages. I transfered my services from Roger's to public mobile
2 hours ago
Are you about to text out? call out? With PM Sim card?
I will private message you the Telus team porting number. They can check the status of your port.
2 hours ago
I had tried a couple of days ago. I have tried again. I'll give it a few hours see if it works this time
3 hours ago
When did you port your number over? It can take a few hours for the port to be completed.
Did you respond "yes" to Roger's port request confirmation request?
