07-12-2020 11:41 AM - edited 01-05-2022 12:04 PM
I am switching my wife over to Public from Petro Canada Mobility. I may have put in the wrong number to port over. Is there a way I can check what number I asked to port over. If there is no way then I assume it will fail at some point if it is the wrong number. Will there be a way to port over the correct number if the first port over fails? Thanks
07-12-2020 02:45 PM - edited 01-05-2022 12:04 PM
I may have mistyped the number to be ported over when I created my account. I am not sure and not sure where to check what I submitted. I mistyped a single number. If it is incorrect all long will it take to fail? If it fails how can a port over a the number to this account. Thanks
