04-06-2020 05:56 PM - edited 01-05-2022 11:20 AM
Hi there!
Just ported my wife's Pixel 2XL from Bell yesterday - tested everything BUT MMS.
There's a few different posts about this solution - but some say to add another apn, some say you don't need to.
Anyone have the settings specifically for the Pixel 2 handy?
Thanks so much!!
Service
04-08-2020 05:17 PM
Im using a Pixel 3a XL running Android Q. I didnt have to setup any APNs and MMS works OK for me. However I did some minor changes based on my device configuration.
My Pixel 3a XL is dual SIM. I have the PM SIM for voice / text and Fido eSIM for data. For the PM SIM, I enabled the option that says "MMS Messages - Send and Receive when mobile data is OFF".
04-06-2020 06:18 PM
@jbutuk Pixel's should automatically pickup the correct APN when using Public Mobile. For MMS to work data on the device must be turned on (Note: it won't use data but data must be on) and check the APN Type it should contain mms as part of the string.
04-06-2020 06:16 PM
Thank you!
04-06-2020 06:07 PM - edited 04-06-2020 06:08 PM
@jbutuk here's the pixel 2 PM APN settings according to Gishan.net https://apn-canada.gishan.net/en/apn/public-mobile/google-pixel-2-xl
You don't have to add another APN. Just save over the one you have now. Here are PM's
The APN type should at least be " default,mms,supl " add dun if you intend to use mobile hotspot. Stay safe.
04-06-2020 06:02 PM - edited 04-06-2020 06:05 PM
@jbutuk wrote:Hi there!
Thanks so much!!
Here is a great site to setup your APN and instructions on how to do it. Find the APN Settings for Public Mobile here!
Added direct link to Pixel 2XL https://apn-canada.gishan.net/en/apn/public-mobile/google-pixel-2-xl
