New activated SIM not working
p_simmons
Purchased a new SIM card Aug 14, and activated, it worked first day, now it’s saying not registered. Please Help.
 @p_simmons
If the sim card works in another compatible phone, then check to see if the first phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
@p_simmons
Try rebooting your phone by powering the phone off then power it back on by holding down the power button.
@Timer wrote:
@p_simmons
you get new number or port your old number to PM.
Whether the customer ask for a number to be ported in or took a new number would make no difference in a situation of the Public Mobile service not working at all.
Timer
@p_simmons
MrSpock
@p_simmons hi did you try reseating your sim?do you have another phone to try it in,try toggling in and out of airplane mode a few times if that fails you can contact
 a customer service agent
you will need to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
