New Usage Report
BIGRICK
I have tried the new data usage report and it's quite good.  You can see daily data usage and sms. However the filter seems a bit broken. My main 'use case' is to go in and check my daily data usage from the beginning of my current term. However when I set this filter,  I just seek the first screen of perhaps 5 days. The next page tab is disabled but I know there is plenty more left. This is definitely a bug, as without the data filter I can see everything.
2 REPLIES 2
@BIGRICK
When looking at the Data Usage Details, best to choose the DOWNLOAD option and move that into an excel format to have a look. You can play/sort with the data this way.
Note, data shows up in the usage details section 6-12 hours after it has been used.
