New Plan 5G upgrade, promos?
Lauchlie
Hello, looking at upgrading my current plan from 4G 15gb for $40 to the new 5G plan for $40. Will I be able to keep my current promos? I have loyalty, friend referral, etc. Do those remain with this change? Thanks!
Lauchlie
Thank you for all the quick responses. Updated to the new plan for my renewal date!
@Lauchlie
The current $40 Boxing Day promo for 60gb of data at 5G will ends soon so act soon to switch your plan. Good chance it will ends January 8 but not sure.
You will keep your existing Legacy Rewards system unless you choose to switch but DON’T switch because you will receive credit each month and is a better system.
Hi @Lauchlie
Yes, plan change won't affect your rewards.  Your rewards tie with your account and not plan.
You can make your plan change and will keep all the rewards you currently have
