New Phone
cleeman
I have purchased a new phone. Can I just switch the SIM card from my old phone to my new phone?  Am I able to keep my current phone number?  If so, is there anything specific that I need to do to make it happen?  Thanks!
2 REPLIES 2
@cleeman  - the account and phone number follows the SIM card. So, yes, remove the SIM and insert into the new phone if the SIM slots/holder are the same size.
SIMs come in 3-in-1 sizes, so adapters can be added or removed as needed.
HALIMACS
That's all there is to it, @cleeman
Just make sure you've used the correct SIM adapters to fit the new device SIM slot tray.
