05-12-2020 11:57 AM - edited 01-05-2022 10:45 AM
Hi, I'm wanting to buy a new phone. Ad says it's GSM only. Will that work on this network?Motorola G7 Power - Unlocked - 64 GB International Model (GSM Only)
05-12-2020 10:59 PM
Thanks. I was looking at that phone also but thought I'd like more battery power
05-12-2020 05:44 PM
05-12-2020 03:54 PM
@DallasW according to this link it's both 3f and 4g LTE compatible. https://apn-canada.gishan.net/en/apn/public-mobile/motorola-moto-g7-power
Welcome to PM. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
05-12-2020 03:52 PM
Thanks for the feedback
05-12-2020 03:48 PM
05-12-2020 12:34 PM
05-12-2020 12:29 PM
@DallasW wrote:Hi, I'm wanting to buy a new phone. Ad says it's GSM only. Will that work on this network?Motorola G7 Power - Unlocked - 64 GB International Model (GSM Only)
Welcome to Public Mobile, from what the members are saying here this phone, its not guaranteed to work, better buy something, you know for sure will work so you're not stuck with it. I personally prefer unlocked iphones don't usually have problems with.
05-12-2020 12:28 PM
@DallasW Is it from Amazon? If yes, and it's the Latin American version then it will work without any issues.
Best if you can provide a link to the phone and we can verify that it works for you.
05-12-2020 12:22 PM
Gsm only is a big no
Even Rogers is getting rid of it
You need 3g phone
05-12-2020 12:21 PM
@ShawnC13 wrote:@Naepalm the IMEI checker only checks to see if the phone is blacklisted or not. I know the one that was on PM's page was even giving false results so it was completely no good to anyone lol
I read that it didn't work well if the phone is from oversee's. Kinda funny that Telus would say to use this method LOL. Only works if the phone is Canadian and has been registered by a Canadian telecom company.
05-12-2020 12:21 PM
it's fine @Naepalm shhhh. 🤫 the phone just needs to have the frequencies.
Motorola G7.Power
Technology | GSM / HSPA / LTE |
2G bands | GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (dual-SIM model only) |
3G bands | HSDPA 850 / 900 / 1900 / 2100 - Europe |
HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 - USA | |
4G bands | 1, 2, 3, 4, 5, 7, 8, 19, 20, 28, 38, 40, 41 - Europe |
1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 20, 25, 26, 29, 30, 38, 39, 40, 41, 41, 66, 71 - USA | |
Speed | HSPA 42.2/5.76 Mbps, LTE-A (2CA) Cat7 300/50 Mbps |
05-12-2020 12:18 PM - edited 05-12-2020 12:21 PM
Edited to add: This is a different checker than what PM had used in the past so looks like this one might work lol
05-12-2020 12:12 PM - edited 05-12-2020 12:28 PM
You can check it against this IME check point: http://mobility.telus.com/devicecompatibilitycheck/?locale=en
I have also read that GSM is not supported by Telus....
(edit: this is relevant because Public runs on the Telus network)
Some phones imported from overseas may not work with the IMEI check above.
Since some phones have specs listing the 3G and LTE Bands supported in place of frequencies:
GSM: Not supported
3G/HSPA/WCDMA: Band 5 (850 MHz), Band 2 (1900 MHz)
LTE: Band 4 (1700 MHz / 2100 MHz), Band 29 (700 MHz)
05-12-2020 12:04 PM
You can use this site for potential phone purchases:
05-12-2020 12:04 PM
It should be compatible. Make sure it is unlocked.
05-12-2020 11:59 AM - edited 05-12-2020 12:27 PM
@DallasW yes this phone is compatible. my friend is using this phone on Public Mobile.
edit: he has the american version
