05-10-2017 04:01 PM - edited 01-05-2022 02:04 AM
Hi folks,
Just a quick note that @Jeremy_M has posted a new Knowlege Base article on Managing your data:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Managing-your-data-usage/ta-p/152760
You may have already discovered it in the KB area, but some people may not check there for updates regularly so I thought I'd link it here as well.
05-11-2017 01:23 PM
@NDesai yeah my post here was probably not needed. Maybe I'll arrange to have it deleted.
05-10-2017 06:53 PM
It appeared as a normal Latest Topic and that's how i found it. You don't necessarily have to check for updates specifically by going to KB boards. Too bad we don't have Latest Post section
or there would be higher chance of people discovering it every time it gets bumped up when someone replies.
05-10-2017 04:45 PM
