11-25-2022 08:36 PM
11-25-2022 09:04 PM
We moved to Maple Ridge back in 2005 from Calgary. At that time there were no 604 mobile numbers available so we took a 778 and I believe 236 and another was added. So if a 604 Sechelt works.....take it! If you don’t like, you can change it at no cost. You might see some numbers for sale on Craigslist etc,,,,,but that will cost you. Also take a look at numbers on voip.ms...but no 604. Voip.ms is a cheap way to get a better pick of a number but will take a week at least to port.
Maybe you know some one elderly or? that does not use their 604 number that you could port. But beware...porting out closes the account. The reason I say that is...I just checked my mother in laws account with a 604# in New Westminster........hasn’t had in inbound or outbound call in the last 6 months and minuscule before that.
11-25-2022 08:52 PM - edited 11-25-2022 08:52 PM
Sechelt IS part of the Vancouver calling group.
11-25-2022 08:48 PM
@clarencetom wrote:Does Public Mobile have numbers with 604 area codes?
I have seen 604 area code phone numbers available, but Vancouver numbers with 604 are unlikely. You could get lucky though.
11-25-2022 08:39 PM - edited 11-25-2022 08:45 PM
Try Sechelt. It's a local call now. It'll just look a little odd to those that use location with the number.
Adding - or Aldergrove. It's a local call from Aldergrove to Sechelt, from White Rock to Port Mellon.
11-25-2022 08:36 PM
I live in Vancouver
