08-22-2019 10:52 PM - edited 01-05-2022 06:35 AM
for net work it shows LTD/WCDMA/GSMauto connect is this the way it should be?
Phones
08-23-2019 05:48 PM
it is on lte set for net work but cant get on net wi fi or reg connection :thanks
08-23-2019 05:18 PM
Agree with @will13am. Throttled LTE is much better than 3G. Especially for uploads and especially at cell edge.
08-23-2019 10:17 AM
@cavemantoronto wrote:
@RODNEY2008 wrote:for net work it shows LTD/WCDMA/GSMauto connect is this the way it should be?
For 3g plan, wcdma only will be faster data.
Totally disagree. At work, 3G data is totally unusable. All the bandwidth is allocated to phone calls during the work hours. Because LTE is more efficient, customers should be encouraged to run LTE preferred and use 3G only on an exception basis.
08-23-2019 12:54 AM
@RODNEY2008 wrote:so I should change my setting or no?
@RODNEY2008 No need to change.
08-22-2019 11:27 PM
Either setting will work.
For 3g plan:
Wcdma only - data will be faster
LTE/WCDMA/GSM Auto - lower delay before data starts working
No emergency alerts unless LTE is turned on.
Setting is up to you.
08-22-2019 11:20 PM
08-22-2019 11:18 PM
08-22-2019 11:01 PM
Yes.
