Network not registered
ebyvarghesepaul
Shows network not registered, even after trying restarting, resetting network settings and taking the sim card out and putting it back. Phone recognizes the sim number in settings.
@ebyvarghesepaul - are you using a SIM card that has been activated? Activation pages here: https://publicmobile.ca/en/on/portal/activation
Note, you cannot reuse a sim card that was on a previous account that has been closed.
If the SIM card is activated and you were charged for a plan:
https://www.telus.com/en/on/outages
will13am
@ebyvarghesepaul , by chance could your account be suspended?  Please check using incognito mode to make sure you are viewing a fresh up to date snapshot of your self serve account.
@ebyvarghesepaul
What type of phone do you have?
dust2dust
Is this just suddenly now? It has been working for a while and now not? Can you try the sim in another phone? Did you buy the phone new?
