Network Settings
11-20-2016 11:08 PM - edited 01-05-2022 12:45 AM
I'm not sure if this is common or not - but when first entering my SIM I had no data. after a bit of quick research - I found some handy info that helped me get online after inputting into my settings:
APN: sp.mb.com
Proxy:
Port:
Username:
Password:
Server:
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type:
APN type:
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
APN PPP phone number: Not Set
These settings will be different for different phones, but you can USE THIS LINK to find the corresponding options for your specific phone with PM. Apologies if this was posted elsewhere, just the first time I've seen it!
Service
11-20-2016 11:40 PM
That site is out of date as it lists 2G as a frequency. PM only supports 3G and LTE/4G.
Glad it helped you though.
