Network Not Available-Asking for Sim Card
aev71
Help
My Public Mobile  network is no longer available. It was working well 2 days ago.
Now it is asking for Sim Card which I did not remove.
No access to service
This account was established over 10 years ago. Not registered
9 REPLIES 9
Yummy
@aev71 wrote:
Found solution 👋. Working💡
Don't keep us in suspense!
What did you do and what was the issue????
 @aev71 : Well??!! 🙂 What fixed it? For the future readers and our own curiosity.
aev71
aev71
Cannot access the Network. Asking to insert Sim. No 611 --NOTHNG ?????????/
 @aev71 : Can you try a Telus or Koodo or other PM SIM in your phone? Did you go through all the suggested ideas and checks provided above? There were quite a few.
If you were to buy another SIM then you can change it yourself in the self-serve. The company might even credit your account the cost if you ask nicely since you've been here so long.
aev71
Tried recommended solutions; no change.
Can I get a new Card . This is my main cell number
@aev71 wrote:
Help
@aev71  - Also, check your Self Serve account, OR dial 611 to ensure your account is ACTIVE.
If all other trouble shooting is not working (and while you have your SIM card out) check the last 4 digits of the SIM match the digits listed on your Self Serve account under "Change Sim Card" option.
Matching is what you want, so that would be a good thing.
Not matching, please report back.
@aev71 wrote:
Help
@aev71  - 10 years, you are a devoted customer!
Can you remove the SIM card and gently clean the contacts of the SIM contact points. Maybe gently blow inside the SIM slot.
Debris could have gotten inside at one point.
Or, the SIM could have shifted. Removing and replacing may help.
Has it gotten wet recently?
 @aev71 : Can you try the SIM in another phone? Can you still log in to your self-serve account? Can you have a look at devicecheck.ca. Have you restarted the phone? Even possibly just removing and reinserting the SIM in the slot or tray.
