Network Issue
Eliza5
Hello community,
Anyone else having network issues this morning.
Unable to make outgoing calls.
Eliza5
will13am
@Eliza5 , no connectivity issues here.  Is your phone showing no network connection?  Often a reboot will take care of such problems unless you live in a sparsely covered area and the local tower is experiencing an outage.
Staliger
@Eliza5 Where are you located? For me here in Vancouver everything works smoothly. Did you try restarting phone/air plane mode/lost-stolen feature?
dabr
@Eliza5 wrote:
Hello community,
Eliza5
@Eliza5  What plan are you on?  If on the $15 plan maybe you're out of outgoing mins and will need to purchase the $5/500 mins add-on to tide you over until renewal?
gpixel
@Eliza5 do you get a warning message when trying to make a call? or do you just hear a beep and then disconnect? make sure everything in your self serve is working correctly
geopublic
@Eliza5 wrote:
Hello community,
Eliza5
@Eliza5  Try putting your phone in airplane mode for 5 minutes and back again or try restarting your phone to see if it helps.
