Need to call twice every time
10-16-2019 11:50 AM - edited 01-05-2022 07:35 AM
When someone call my PM number , every time need to call twice , First time always connect to the voicemail . The second call can be made .
Phones
10-16-2019 03:27 PM - edited 10-16-2019 03:29 PM
@kevinqqh wrote:When someone call my PM number , every time need to call twice , First time always connect to the voicemail . The second call can be made .
@kevinqqh sounds like you accidentally turned on do not disturb mode on your phone.
EDIT: more info for iPhones, and for Android phones.
10-16-2019 02:22 PM
@kevinqqh on iPhones and most android theres a setting in the do not disturb menu for repeated calls get thru! Kinda sounds like that, the setting is if a second call comes in within 15 minutes from the same number then the phone will ring
10-16-2019 02:13 PM
@kevinqqh Check your phone settings and make sure you don't have any type of call blocking/filtering enabled within your contacts.
10-16-2019 12:14 PM - edited 10-16-2019 12:18 PM
How is your reception?
How many rings do you have set before passing to voicemail.
How many times does this happen and can you boil down the times?
What shows on your call log? Can you take some screenshots?
Do you have anything phoneset that you could borrow to try your sim in?
You can also contact moderators to reprovision your account
