Need help with auto pay
Parin1
cavemantoronto
@Parin1 what did you try and what was error message?   Or are you asking how?
Triguy
If you want to setup autopay, here is more info.
Setting up AutoPay means that you earn $2 every 30 days!To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
GinYVR
@Parin1Can you elaborate what do you need help with?
