08-23-2016 01:56 PM - edited 01-04-2022 03:06 PM
08-23-2016 03:47 PM
In theory you will only need 1 cell phone. Once you have set forwarding from PM to new number, try swapping the sims and have someone call your PM number.
08-23-2016 03:00 PM
08-23-2016 02:45 PM
@Shaunpaul Forwarding seems a decent workaround as long as your are forwarding your PM number to the new one; if it is not within your calling plan be sure you have the long distance add-on.
Remember PM will only operate within Canada.
08-23-2016 02:32 PM
@Shaunpaul, glad you found a workable solution.
08-23-2016 02:30 PM
08-23-2016 02:16 PM
Unfortunately no, there is no way to keep your account when you port out. Your account will automatically get deleted when you port out.
PM doesn't offer refunds as it is a pre-paid service.
