08-16-2019 06:29 PM - edited 01-05-2022 08:35 AM
08-16-2019 06:54 PM
Thanks so much for your help. I will try again later. 😞
I hope it will work.
08-16-2019 06:52 PM
@kissifer19 it may just be the wonderful system acting up again or I know in the past there are a few businesses that dont do there accounting until later in the evening you may find they will work in a few hours or in the morning ,I know it has happened to me in the past
08-16-2019 06:50 PM
Unfortunately, voucher issues happen frequently.
You could wait for moderator response or maybe try tomorrow morning. Sometimes, there is a delay in activation.
If you really need service, you could buy an online voucher at recharge.com (there is a service fee though). At least, then you can get your service going if it is suspended presently.
08-16-2019 06:43 PM
I tired to add it online and through 611 😞 Still the same thing. 😞
08-16-2019 06:41 PM
@kissifer19 you can also try your self serve account if you havent already
08-16-2019 06:40 PM
Dominion which here is loblaws.
08-16-2019 06:39 PM
@kissifer19 wrote:omg serious? I bought a voucher and it will not work. Went back to the store and they printed me a new one and it still wont work. 😞
Yeah...vouchers...sometimes they don't work right away. Did you buy it at Shoppers? Which value?
08-16-2019 06:38 PM
Yip! Keeps saying Unfortunately, Voucher # could not be added. Please verify the Voucher and try again.
08-16-2019 06:37 PM
@kissifer19 did you try to dial *611
08-16-2019 06:35 PM
08-16-2019 06:34 PM
@kissifer19 there seems to be a 2 or 3 day wait right now
08-16-2019 06:34 PM
@kissifer19 wrote:Thanks I sent off an email. Do you know how long it takes to get a reply?
Could be a couple days.
What problem are you having that makes you want the moderator?
08-16-2019 06:33 PM
08-16-2019 06:31 PM - edited 08-16-2019 06:33 PM
@kissifer19 Hi is there anyting we can help with?you can contact one here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
