12-13-2020 12:38 PM - edited 01-05-2022 04:28 PM
Phone says " no sim" , can not receive calls or texts , any solutions
12-13-2020 03:25 PM
@Jacklabel48 and others FYI: found this post in another thread and moved it to this one.
12-13-2020 02:03 PM
@Jacklabel48 wrote:Phone says " no sim" , can not receive calls or texts , any solutions
@Jacklabel48 hi there! Try removing the sim card and wiping it down. Reboot.
This works for some customers and I hope this helps you too.
Best wishes and season's greetings! 🎄🎄🎄
12-13-2020 01:57 PM
@Jacklabel48 wrote:Removing the sim card and wiping it down worked !!
Hi @Jacklabel48 nice to know that removing sim card and wiping it down worked for you.
12-13-2020 12:54 PM
We're you ever able to use it with Publicmobile/Koodo/Telus? It may be locked to previous provider.
Your phone is not blacklisted, right?https://www.devicecheck.ca/check-status-device-canada/
12-13-2020 12:42 PM - edited 12-13-2020 12:42 PM
If you have an iPhone with no sim error, update carrier specific update. You may need to connect your iPhone to iTune running on PC.
12-13-2020 12:40 PM - edited 12-13-2020 12:41 PM
Are you a new customer?
Did you try rebooting or reset network settings?
What is your account status in self service?
Log into self service and choose Change Sim Card and ensure the last 4 digits match your SIM card to ensure you have not been sim jacked. If they do not match put your phone in lost/stolen mode in self service and change the password. Then check and secure all your financials.
12-13-2020
12:40 PM
12-13-2020
03:27 PM
Luddite
[Solution found in another thread & moved here ........ Luddite]
