NO INCOMING CALLS
06-11-2020 07:49 PM - edited 01-05-2022 11:39 AM
Hi,
I recently ported in my number from Chatr wireless to PM. It is been more than 6 hours of porting in. I am not receiving calls other than Telus Network. I submitted request to a moderator, he asked for further details and it is been more than 2 hours that I did not hear back. It is so frustrating. I did all the necessary troubleshooting but all in vain. PLEASE HELPPPPP
Phones
06-11-2020 11:02 PM
Cheer up.
If even after a network reset, you are not getting incoming calls, then it is a technical issue in porting your phone number.
Give the Moderator Team, more time.
They will fix it , sooner than later!
Regards.
06-11-2020 10:52 PM
Unfortunately, it did not work either.
06-11-2020 08:40 PM - edited 06-11-2020 08:41 PM
@mikeklemak darn.. try the lost/stolen feature to try and reset the sim network. go into your self serve and enable the feature for 5 min and then disable it
06-11-2020 08:39 PM
Thanks. So far, no dice.
06-11-2020 08:38 PM
No calls yet.
06-11-2020 08:21 PM - edited 06-11-2020 08:24 PM
@mikeklemak try resetting your network settings
- open settings>advanced settings
- tap backup and reset
- tap network settings reset
- tap network settings reset and confirm
- restart and test
06-11-2020 08:20 PM
If you supplied with correct Chatr info, it will take about 30 minutes for Chatr to release your phone number to PM.
Chatr online does not show your your account number.
Did you call Chatr to get your account # before porting?
1. Your Chatr number must be active to port.
2. PM need your Chatr account #, name on the Chatr account and the phone number to be ported. If you provide more info, there is more chance that the extra info may be wrong to stop the porting process.
Welcome to PM.
Have a better and better days!
06-11-2020 08:18 PM
@mikeklemak so, are you getting some calls like @RanaShahid too? Thanks.
06-11-2020 08:17 PM
@RanaShahid You just need to be patient the moderators will respond and the port will complete and you will be able to receive calls.
06-11-2020 08:17 PM
@RanaShahid , the best way to check when your number port is complete is by continuing to use the old service. When that service disconnects, your port is complete. Normally ports don't take more than a couple of hours. Definitely follow up with the moderators.
06-11-2020 08:17 PM
Huawei P20 Pro
06-11-2020 08:15 PM
@mikeklemak what's the make and model of your phone?
06-11-2020 07:59 PM
I'm dealing with the same thing right now. Put a ticket into the moderators. I'll let you know when they figure it out.
06-11-2020 07:52 PM
@RanaShahid hi if you already contacted the moderators you will have to wait while they look into your issue hope it's resolved for you soon good luck
06-11-2020 07:52 PM - edited 06-11-2020 07:55 PM
@RanaShahid try restarting your phone. Take out and replace the SIM, wait 30 seconds and restart it. Whats the make and model of your phone? Welcome to PM. Stay safe.
06-11-2020 07:51 PM - edited 06-11-2020 07:52 PM
@RanaShahid just send another message to the Moderators through your private messages from a previous reply.
what type of phone do you have? maybe all you need is a network reset
