11-14-2022 09:17 PM
My data plan is 1 gb plus 2 Gb bonus for 12 months. But I just enrolled my plan only 6 months, no 2 gb bonus part. Why?
11-14-2022 09:22 PM
@billyqing have you make any plan change lately? If a plan change made, the 12 month 2GB bonus will be gone
Try to logon to My Account Using Incognito mode and see if you see the 2GB
Also, it could also be gone from My Account if you have used up your 2GB on this month. If it is this case, you will see the 2GB again on your next cycle
If you are certain you didn't used it up on this cycle, and you checked with Incognito mode and still don't see it, open ticket with PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
