My avcount
Buggerfly
New Neighbour / Nouveau Voisin
I nees help resegting username or password please
2 REPLIES 2
LovesToPM
@Buggerfly
If you want to find the email used for your Community account(s), you will find it here in your settings.
Try using the forgot password link at https://selfserve.publicmobile.ca/forgot-password/
If that doesn't work, you will need the moderators to help you.  They can be contacted by private messaging through this link:   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
