My account
Lee_1969
 I thought I was registered but I can't log on. Can I possibly do it all over again. Something went wrong when I did it the first time
10 REPLIES 10
Lee_1969
 Thanks for the help
Lee_1969
Thanks, I'll try that. I really appreciate everyone's help. This is an amazing community
Lee_1969
 I hope so 😁 and good luck to you too
wisekal
I came in to post about the exact same issue. I too am unable to log into certain accounts.
Hopefully this is a technical issue on their end and will be resolved soon. Good luck!
@Lee_1969
the issue in your browser if can use page inPrivate mode, maybe you can login
if want to contact support team by private message CS_Agent  to change email and set new password.
@Lee_1969
Go to SIMon Chatbot and type in create a ticket at the bottom of the page or private message them on the envelope icon above.
Lee_1969
Don't have a computer. I'm not very good at all that stuff
Lee_1969
How do I get ahold of an agent. I tried that, it didn't work. I think somehow I messed up my email,that's why it's not working
@Lee_1969
Enter your email address and click on Reset Password.
If you still can’t login, contact a CS_Agent to help you access your account.
Timer
@Lee_1969
tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
