04-19-2022 12:19 PM
I just activated my Sim card and when I phoned my cell phone from a different phone it went straight to voicemail. I urgently need this fixed please.
thanks Keith
04-27-2022 07:16 AM
Thanks everyone for your assistance, I appreciate it.
04-19-2022 02:19 PM
@Keith1953 Try:
If stills issues, are your outgoing calls and texts in/out working?
If you ported over a number to Public Mobile, Ii would be the incoming calls that may be delayed, as that particular service takes longer to port over across providers.
So, use the previous provider's SIM card to receive calls from. When the incoming calls stop that is a good indication the port is complete.
If still issues, submit a ticket for help with Public Mobile Customer Support Agents; click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
04-19-2022 01:07 PM
When you activated your new PM service, did you chose new number or you initiated porting at the same time?
04-19-2022 12:38 PM
Are you porting your old number to PM?
If yes, you need to reply to the text from your old carrier with the old SIM in the phone.
If you picked a new number, just reboot your phone by powering off then power the phone back on.
