My Plan
UncleRoger
I thought I had an unlimited talk and text plan. Was this changed on my plan?
hairbag1
If you're referring the the "long distance charges may apply" message when you initiate a call...just ignore that message. There won't be any long distance charges.
If you want, just add 1 ahead of the area code.
No matter what happens...you won't be billed any extra charges for calling/texting/data. If you don't prepay for something, you don't have it to use.
popping
If you have the $15 plan, you have 100 outgoing minutes + unlimited income minutes + unlimited text.  You can purchase $5 500 minutes add-on as backup.  Unused add-on minutes will roll over to next cycle until they are used.
All other current plans are unlimited talk and text plans.
JoyLuck
What plan are you on?
All current plans on PM's website have unlimited texting and unlimited calling except for the $15 plan which has 100 outgoing minutes.
