Multiple lines on same account?
pashadee
Hi guys,
I currently have a line wit Public mobile and would like to add one or two more lines, it's not very straight forward on how to do that... if anyone has already done that I would appreciate the help.
thanks
15 REPLIES 15
@agmilaya Try using a gmail account + aliases. For example if your email is agmilaya@gmail.com. one could agmilaya+kid@gmail.com, another agmilaya+hub@gmail.com. keep them under 30 characters.  Stay safe.
agmilaya
I wish this is something the PM can change or address and be able to have a unified 1 username access instead of having multiple email address to access different accounts. Koodo does it and other carriers..... just saying...
srlawren
@Lieux wrote:
What the point the advantage to have an email with dots???
@Lieux the point that may not have been terribly clear in the responses to this post so far is that every account must have a unique email address assigned to it.  Using the gmail tricks that @mimmo mentioned means that you can effectively create more than 1 unique email address that end up in the same single Gmail account.  More here:  http://www.thewindowsclub.com/gmail-address-tricks
mimmo
@Lieux the alias allows one person to manage multiple accounts using the same address.  I use name+mom and name+dad@gmail.com so that they do not need to be bothered with it.
@mimmo thanks for clarification... so what happened when you have an email with a dot during the identification??? Only one person can receive the message???!! What the point the advantage to have an email with dots???
Sharry19
@pashadee Just to let you know PM is a Prepaid service not post paid so per line you have to make separate account.
*** Please note: I am not a Moderator ***
pashadee
Thanks for the responses guys. I guess I got my answer, that it is not possible to manage multiple lines from one account.
Exact @pashadee you will need to create 3 different usernames and passwords for your different numbers...you will be able to manage but in 3 differents accounts... I have read that you can use a same email adress but with . Or +.... but I m not sure.. someone else can explain to you..
mimmo
1 phone number /1 account per  email address.
If you use Gmail you can create a Gmail alias name@gmsil.com = na.me@gmail.com =name+son@gmail.com
Be aware the + is not valid though when doing account verifications for mod communication.
pashadee
That's sweet 🙂
pashadee
Thanks for the response Lieux.. I am looking at having 3 phones with 3 different sims and 3 different (or same) plans ... I'm not sure if what you are saying is that I have to create 3 separate accounts for this and pay with the same credit card? If that's the case that's pretty inconvenient.. it would be nice to just login with one user and password and be able to manage / pay for all 3 lines.
missorange
you need to register and activate different sim card, not adding to the same account.
Lieux
And you can refer one sim for another one and have a 10$ credit on the second one... @pashadeeSmiley Happy
Lieux
Hello @pashadee
We have 4 plans here but a plan is for one person one number.... you will need many SIM cards if you want more than one number... you can pay with the same credit card...
