06-16-2015 03:07 PM - edited 01-04-2022 01:39 PM
I use a Samsung Ace but was recently given a Galaxy S5 by a friend that I would like to start using. The SIM cards are completely different, so it is not a simple matter of switching the SIMcards. I understand that one can snip/alter/cut up the larger ( in size) SIM card from the Ace to make it fit the Galaxy SPOT , but I would rather not take that chance of ruining the card. Also because this site is in beta I cannot order another SIM card.
How can I transfer all memory , number and contact info to the Galaxy from the Ace?
06-16-2015 06:29 PM
06-16-2015 03:11 PM
The Galaxy S5 need a microSIM.
The fastest way is to have your actual SIM card cutted to microSIM. Some shops do it for you with a precision cutter.
OR
How to request a FREE replacement SIM card by email ?
Click on this link : https://publicmobile.ca/en/on/contact-us
Then, at the bottom right of the page, click on "Email away" button.
- Choose "SIM & Activation"
- Choose "Activation"
- Choose "I activated my phone and SIM card more than 24 hours ago"
- Choose "I did not receive an error message"
Then click on "Email Us" and fill up the form.
Important: Make sure you provide us a full mailing address, an alternate contact number, and the size of the SIM card (Nano/Standard/Micro) needed. Is should look like this:
All SIM card replacement orders will be processed within two business days, but it may take up to 7 business days to receive your new SIM.
If you did not receive your SIM card within the timeframe, please check your mailbox before sending us an email.
Once you receive your replacement SIM card, you have to update your SIM card number on your account by login to your self serve account, then click on "Change SIM card number"
