Moto One Compatability?
Kevtd
I cant find the Motorola One on the compatability checker and have found conflicting information on what frequency bands it actualy uses.
Has anyone had any success using one on PM? I havent bought it yet.
@Kevtd wrote:
Havent bought it yet but this one
https://www.amazon.com/Motorola-Moto-One-Smartphone-International/dp/B07MF3JYYT/ref=sr_1_1?keywords=...
@Anonymous wrote:
Full name model/submodel? Where bought? Which previous provider?
Edit Correction.
This one specificaly
https://www.amazon.ca/Motorola-Unlocked-Smartphone-International-XT1941-3/dp/B07MF3JM4T/ref=sr_1_3?k...
Will it working only on some bands affect my coverage?
I note that you've claimed your own answer as the Solution to your question. I think the Solution should be given to someone other than yourself as you didn't really provide your own answer.
You can edit your Solution by clicking on the 3 dots on top right side of dialogue box to amend your Solution.
Cheers
Edit Correction.
From those specs it looks like it'll be fine as already mentioned.
Kevtd
Edit Correction.
bridonca
lt will work.  This phone can use all of the 3G bands, and most of the LTE bands, Public Mobile supports.
https://www.gsmarena.com/motorola_one_(p30_play)-9310.php
