More data
tankrd
Is there anyone to talk to here that can offer a better data deal for a loyal customer?
I'm not a data guy, but yes, that 8 GB/30-day plan for $50 is a good looking deal.  Sure, it's throttled LTE speeds, but the latency is low, the current deal contains Canada-wide and US Calling (minus a couple US area codes), and international SMS & MMS.
If you want 8 GB of data, it's priced very well.
You could pay the same price at the orange carrier - but the network is nowhere near as good as it is here.
austinhuang
You have $1~$5 loyalty rewards already. Don't think a loyalty plan would be possible given that an incentive is already in place.
If this solves your question, please select my reply as Solution!
KMG
The best data deal is currently $50 for 8GB.  I would argue that it won't be easy to find a better deal than that!
https://productioncommunity.publicmobile.ca/t5/Announcements/UPDATED-Get-6-GB-at-3G-speeds-for-45-OR...
KMG
No, there isn't.  Public Mobile does not have a loyalty department.  The plans offered (https://www.publicmobile.ca/plans) are the only ones available, and they are available to all existing customers and new customers equally.
