05-22-2026 05:41 PM
05-23-2026 01:56 PM
where you see the 2 charges "one after another"?
If they are on Payment history on My Account, please note that each renewal will show at least two transactions on payment history on My account. Only one entry shows actual PM charge, show how much PM charged your card and applied the amount to your Available Fund in My Account. The other entry, likely couple hours later on the same day, will be showing how PM uses the money from your Available fund in My Account for plan renewal.
Post us a screenshot of you have any question.
If you are certain there are more than one posted charge (and not pending) on your credit card and you cannot find where the extra money went, engage support for further investigation:
05-23-2026 01:53 PM
Yes, I see both charges one after another and no refund
05-22-2026 05:49 PM
Did you see the 2 charges on credit card or on PM Payment history?
If on PM payment history z that 2 transactions are just 1 charge, not 2
But if credit card, ask PM to check
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
