02-22-2025 07:58 AM
Does Public Mobile email me a reminder to pay upcoming monthly invoice as similar with hydro, electric etc?
02-22-2025 10:00 AM
Yup @Jcs2 , that works too re data management. 👍
One minor point is that one cannot “go over” their data allotment. Once it’s used, data just stops. There are no overages or surprise charges for services here.
02-22-2025 09:19 AM
@HALIMACS Suggests a great idea, adding to calendar event. I have autopay, however you could use your calendar to ‘reset ‘ data on your monthly basis. I use this to confirm I don’t go over data allotment using iPhone under cellular in settings. It helps me to check my account and rewards amount too.
02-22-2025 08:09 AM
Regrettably, @MeganHonsberger , they do not issue monthly reminders.
What users can do is subscribe to auto-pay (if they wish), then they'll automatically take the payment required to keep service active.
If you wish to manually pay prior to plan expiry, you could set a recurrent 30-day reminder on your choice of calendar (not monthly as cycles are 30 days, not monthly) to remind you the day before your expiry.
