Money back
ParticioGuerron
If money was already taken and no service is being provided. I want my money back.
2 REPLIES 2
hi @ParticioGuerron
If you have worked with PM support agent and they cannot help, then yes, they will issue refund
But have you try asking PM agent to help?   what have you done so far to get the issue resolved?
are you porting in the phone number? did you remove the old carrier sim card (or disable old carrier esim)?
Check if PM sim is enabled and set as Primary.  Then try Reboot phone and reset network settings
if same, you will need to check with PM support agent and they can help.
you can submit ticket by direct message:
slusagm
ask PM to help first.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
