Moderator
Andrew5729
  • How do I submit a ticket
@BKNS27 wrote:
@Andrew5729
Click your avatar then Messages and send to CS_Agent.
Or click on Chatbot then type in Submit Ticket.
Is there something we can help you with for a quicker response?
It's not a matter of choosing one or the other. Sending a private message to CS_Agent as the initital contact method is only meant as a backup/last resort.  Customers are required to submit all tickets using either the chatbot or using the support section of the Public Mobile app.
HALIMACS
@Andrew5729
To contact a Customer Support Agent, there are 2 methods; please use the 1st method first:
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
@Andrew5729
